Hello Guest it is October 24, 2026, 03:32:12 PM
Author Topic: how to wire PNOZ X7 with drivers MR-J2S-60A and CSMIO-IP-A  (Read 47872 times)
Offline sdow
  •  67 67
Offline sdow
  •  67 67
Re: how to wire PNOZ X7 with drivers MR-J2S-60A and CSMIO-IP-A
« Reply #1 on: April 07, 2014, 01:59:55 PM »
or do i need to use PNOZ with my drivers
« Reply #3 on: April 10, 2014, 02:38:58 AM »
Sorry have been snowed under with work  the last while and have not been able to spend so much time here. I will try and have a look sometime later today if I get a chance.
« Reply #4 on: April 11, 2014, 05:17:55 PM »
Ok I assume you are wanting to connect in a similar manner to the diagram in the IP-A manual?
If yes then the Emergency Stop signal to your drive would be used. It requires a connection to 0v on your drives, ie break the connection and the drive E-Stops. To do that you would have SG (CN1B 10) one side of the relay contact on the PNOZ and the other side of the relay would be to EMG (CN1B 15)
See pic below.
Offline sdow
  •  67 67
« Reply #5 on: April 11, 2014, 05:36:32 PM »
hi hood
yes i do exactly that  .... but when push the button ESTOP   and after the ST1    ... my controllers stay in alarm ... how to activate normal mode .
« Reply #6 on: April 11, 2014, 05:45:54 PM »
You may need to use the drives Reset.
Offline sdow
  •  67 67
« Reply #7 on: April 16, 2014, 04:35:46 PM »
hi in your picture  de fault from driver 1  .... where it go .... i have not ( input auxiliary alarm  for the second driver )
« Reply #8 on: April 18, 2014, 09:26:14 AM »
If wanting to wre as CSMIO suggest then you would link the three fault signals from your drives and put them into the E-Stop circuit. That is assuming of course that the fault output from your drive is +24v when there is a fault and not _24v when there is no fault. If it is the latter then you would need to invert the signals vial relays or similar.
Offline sdow
  •  67 67
« Reply #9 on: April 18, 2014, 09:34:42 AM »
ok I recommend not using the PNOZ ?
