Hello Guest it is November 13, 2026, 12:27:54 PM
Author Topic: Basic wiring diagram from LPT port to stepper driver?  (Read 18322 times)
« on: April 05, 2014, 11:33:57 AM »
Hi!
Being completely new to cnc and steppers in general, i have a very basic question which i have not found answered elsewhere (even after extensive searching).
I have wired a stepper motor and driver to a power supply as seen in the following picture:
Now i am trying to define in Mach3 which pins of the LPT port
are supposed to belong to the x axis:
In this case, the first and second pin of the LPT port are my "step pin" resp. "dir Pin".
How do i connect those pins to the driver?
My driver http://www.ebay.de/itm/CNC-Router-Single-Axis-TB6560-3-5A-2-Phase-Stepper-Motor-Driver-Board-Controller-/261160006615 has six pins still available:
EN+
EN-
DUR
DIR+
PUL-
PUL+
So, how do i connect those? Is there any basic wiing or scematic?
Yeah i know i must sound kinda stupid, as this question is probably trivial to most of you. However, i am totally lost. Please help me out!
Best regards,
Andy
Re: Basic wiring diagram from LPT port to stepper driver?
« Reply #1 on: April 05, 2014, 12:41:28 PM »
It looks like there is a typo on the drives, it has DUR and DIR, both should be DIR.
The Pulse is the Step input, same thing just a different name.
Your drives can accept differential Step/Dir signal and it will depend how things are connected internally but likely if using single ended Step/Dir signals then you would connect either the + to your 5v or the - to 0v and the Step/Dir signals would go to the opposites.
You really need to get info from the vendor however as to which way is best.
Offline Davek0974
  •  2,606 2,606
« Reply #2 on: April 05, 2014, 12:59:17 PM »
You are missing one vital bit of kit surely - a breakout board??
This is the device that connects your parallel lead to the drives, it also provides essential isolation as it very easy to damage a parallel port.
Search for "CNC breakout board" and all should become clear.
« Reply #3 on: April 05, 2014, 01:36:28 PM »
He Guys,
Thanks for the clarifiations!
@Davek0794:
I will order the breakout board today. Thought about etching it myself, however i found some nice boards using optocoupling for isolation.
@Hood:
Typos... the last thing i would have thought about. Well, i guess i got what i payed for (greeting to China). I might consider bying 'made in Germany' next time.
Best regards,
andy
Offline Davek0974
  •  2,606 2,606
« Reply #4 on: April 05, 2014, 01:41:44 PM »
One other thing, be very careful with those drives, I bought three for my build and one failed after a couple of hours, they are very low spec builds and some use cloned components, only good for low power usage. My ones were rated 5A and I was running 4A I think, they also get very hot.
I'm using the genuine items now and they do not get warm at all.
« Reply #5 on: April 06, 2014, 05:45:24 AM »
Davek, thanks for your warnings! I have hugely overdimensioned my steppers and drivers for my purpose, so i hope they will be fine!
thanks again,
andy
