Hello Guest it is November 13, 2026, 01:02:13 PM
Author Topic: Mach 3 and LazyCAM  (Read 19357 times)
Mach 3 and LazyCAM
« on: April 05, 2014, 05:42:14 AM »
I am aware that Lazycam is no longer supported, but find it useful for simple profiles.
I recently had to reload Mach 3 and Lazycam and they are both accessible on the PC
However, when in Mach3 I cannot access Lazycam as I have previously ie File - Lazycam.
I just get "File not found"
Is there some linking action I need to take. ?
Re: Mach 3 and LazyCAM
« Reply #1 on: April 05, 2014, 07:56:02 AM »
You need to install / reinstall LazyCam, when prompted, just after installing Mach.
« Reply #2 on: April 05, 2014, 08:38:18 AM »
Hi Rich,
Do I have to reinstall Mach 3 then ?
I have tried deleting Lazycam and reinstalling but I did not get the prompt you mention.
Geoff
« Reply #3 on: April 05, 2014, 12:30:56 PM »
Just reinstall Mach over the top of itself and make sure you choose to install LazyCAM while doing the Mach install.
« Reply #4 on: April 05, 2014, 06:33:14 PM »
Geoff,
Just do as Hood has stated.
« Reply #5 on: April 06, 2014, 02:57:18 AM »
I have tried to reinstall Mach 3, but get "Launcher Error Box showing - Could not start set up"
I tried deleting Lazycam and then installing Mach 3, but got the same message.
Geoff
« Reply #6 on: April 06, 2014, 04:06:18 AM »
Geoff,
Using XP here and have never had a problem installing Mach or recieved that error.
What version of Window's are you using?
« Reply #7 on: April 06, 2014, 10:51:56 AM »
Rich,
I am using Windows 7 64 bit
Geoff
« Reply #8 on: April 06, 2014, 02:40:09 PM »
Someone else will need to reply on use of W7 - 64 bit for LC and also the wizards since I don't use that system.
Sorry,
« Reply #9 on: April 07, 2014, 01:46:27 AM »
Try running as admin.
I have just installed Mach/LazyCAM here no problems on  W7 64bit
