Hello Guest it is November 13, 2026, 12:46:09 PM
Author Topic: Mach3 install question  (Read 11730 times)
« on: April 02, 2014, 09:54:11 AM »
Downloaded Mach3 demo some time ago to try it out. Got my (licensed) Mach3 disc yesterday and installed. When I open up the program, at the top of the screen it still says "Mach3 Demo". I thought the licensed version would override the demo version. Can anybody explain why it didn't.
Re: Mach3 install question
« Reply #1 on: April 02, 2014, 10:56:06 AM »
You probably didn't install it correctly.
Did you place the file named Mach1Lic.dat in the \Mach3\ folder?
« Reply #2 on: April 02, 2014, 02:50:15 PM »
Thank you very much. That was the problem.
« Reply #3 on: April 08, 2014, 11:58:36 AM »
hi there,
i have a big problem
i was using mach3 untill my computer crushed.
I wonder if i can install mach3 again and reload my old settings.
i have  mach3mill.xml file and my secreen.set
do i need to re calibrate the steppers?
thanks all
Best Regards
Gokhan
« Reply #4 on: April 08, 2014, 01:56:47 PM »
If you have the xml for the profile you were using on the old computer then all your settings will be intact.
« Reply #5 on: April 11, 2014, 06:12:29 AM »
Thanks Hood
i have my mach3 on a new computer, works as before.
Best regards
Gokhan
