Mach Discussion => General Mach Discussion => Topic started by: GrandpawB on April 02, 2014, 10:54:11 AM
Downloaded Mach3 demo some time ago to try it out. Got my (licensed) Mach3 disc yesterday and installed. When I open up the program, at the top of the screen it still says "Mach3 Demo". I thought the licensed version would override the demo version. Can anybody explain why it didn't.
You probably didn't install it correctly.
Did you place the file named Mach1Lic.dat in the \Mach3\ folder?
Thank you very much. That was the problem.
hi there,
i have a big problem
i was using mach3 untill my computer crushed.
I wonder if i can install mach3 again and reload my old settings.
i have mach3mill.xml file and my secreen.set
do i need to re calibrate the steppers?
thanks all
Best Regards
Gokhan
If you have the xml for the profile you were using on the old computer then all your settings will be intact.
Thanks Hood
i have my mach3 on a new computer, works as before.
Best regards
Gokhan
