Hello Guest it is November 11, 2026, 12:12:50 PM
Author Topic: Mach3 sees home switches but does not stop on homing operation  (Read 13909 times)
Offline twehr
  •  11 11
I am using Mach3, Smoothstepper (USB). I have home switches installed Normally Closed (gnd). Active High. (See attachments)
When I activate the switch (manually), Mach 3 see the home switch. But when I do a home operation, it ignores the home switch.
Help appreciated.
Re: Mach3 sees home switches but does not stop on homing operation
« Reply #1 on: March 30, 2014, 08:09:42 PM »
What exactly is it doing? The green box around the X label would indicate that it's homed.
Offline twehr
  •  11 11
« Reply #2 on: March 30, 2014, 09:12:57 PM »
That came after doing escapes to stop it from crashing.
When I tell it to home ( x in this case) it starts moving in the appropriate direction. I would manually hit the home switch but it would continue to travel. It should stop and retrace till I let go of the switch.
When using the esc key, it reacts correctly.
The switch is working and mach3 diagnostics see it. It just does not halt/reverse the movement.
You may have noticed Gerry, that I am using the 2010  screens (love it). I did test with straight mach3 screens as we'll and the behavior is e same.
« Reply #3 on: March 31, 2014, 03:57:25 PM »
So, if you activate the switch, the LED lights up in the diagnostic screen, but not while it's homing?
Sorry, but I don't have an answer for you.
