Hello Guest it is November 18, 2026, 10:27:40 PM
Author Topic: Hi, Where can i get the wiring diagram to the board of a CNC 3040?  (Read 36637 times)
I know this is the wrong place but I have to try...
One compounent is dead...
Thanks!
  •  9,377 9,377
Re: Hi, Where can i get the wiring diagram to the board of a CNC 3040?
« Reply #1 on: March 22, 2014, 11:43:27 AM »
A photo of the inside of the controller box and a photo of the dead component would help identify which board you have.
« Reply #2 on: March 23, 2014, 03:59:29 AM »
It is a YOOCNC PW 3618 board and I but a mark on whats burn..
Thanks!
Finland
  •  9,377 9,377
« Reply #3 on: March 23, 2014, 06:29:05 AM »
There may be slight differences but I hope this helps.
« Reply #4 on: March 23, 2014, 07:20:43 AM »
Thanks!
I will give it a try and let you know then!
Thanks!
« Reply #5 on: March 24, 2014, 08:03:58 AM »
It didn't work.. I was spinning about 2min and 2000rpm and then it burns again.
thanx
  •  9,377 9,377
« Reply #6 on: March 24, 2014, 08:18:11 AM »
Check D4, R3 and R4 are OK also check solder joints D4 – R3/R4 – IFR630.
« Reply #7 on: March 25, 2014, 02:47:21 PM »
The wiring diagram said that it is a 100 ohm resistor but it burnt right away...
Did I something wrong or was it the diagram for this board?
Thanks!
  •  9,377 9,377
« Reply #8 on: March 26, 2014, 02:07:44 AM »
There are many possibilities ;
If either R3 or R4 had expired then too much current would flow in the opto isolator circuit. Likewise if the capacitor C9 was faulty there would be similar consequences. There is always the possibility that the opto isolator EL817 is at fault but then – that’s the joy’s of fault-finding. :)
« Reply #9 on: March 26, 2014, 06:08:28 AM »
It works now but when I'm trying to do something with the cnc so it will drill straight down about 8mm, but i should only go about 3-4 mm..
But after the first 8mm then it will do the 3-4 mm as it should do.
Why so?
Is it the Board or some settings?
Thanks!!
