Hello Guest it is November 10, 2026, 03:03:52 AM
Author Topic: Hi, Where can i get the wiring diagram to the board of a CNC 3040?  (Read 36445 times)
  •  9,376 9,376
Re: Hi, Where can i get the wiring diagram to the board of a CNC 3040?
« Reply #10 on: March 26, 2014, 06:25:34 AM »
I think the first thing you should do is check your GCode ;
Is your machine / Mach3 doing exactly what the GCode is telling it to do ?
If this is true then it is likely that your CAD/CAM software settings need changing.
Perhaps post your GCode file, then it can be checked here.
« Reply #11 on: March 26, 2014, 06:33:52 AM »
I put my file here. When I start the mach3 I put the wood on to the cnc and the blade to the wood surface and then zero all the X Y Z axises and then start.. But then it will drill strait in to the wood about 8MM
Thanks man!!
« Last Edit: March 26, 2014, 06:36:52 AM by SirFinland »
  •  9,376 9,376
« Reply #12 on: March 26, 2014, 07:21:09 AM »
GCode looks OK and it runs just fine here.
However, the first Z move is a G00 rapid up by 25.4mm – if your Z axis velocity / acceleration settings are set too high then the Z axis may be stalling / loosing steps during this move and then have lost correct position.
Try halving (reduce by 50%) your Z axis velocity and acceleration settings in motor tuning and then see if this makes a difference.
« Reply #13 on: April 19, 2014, 02:02:39 AM »
Thanks for the help it helpt me! But now i have a Little problem...
Do you know what to do? The cnc3040 board is okay, and one day I was engraving and after 10 min when it was done so the spindle didn't stop, it keep runnig no difference if the spindle was on or off and the Emergency stop didn't work. So now when I put the Power on so the spindle is Always on and I can't change the speed on it.
What could be wrong?
Thanks!!
  •  9,376 9,376
« Reply #14 on: April 19, 2014, 02:33:00 AM »
I would suspect that the IFR630 (or one of it’s control components) has become short circuit.
Please forgive me, I don't mean any disrespect, but better quality electronics may be the way forward.
« Reply #15 on: April 19, 2014, 02:50:08 AM »
Yes I Would want to make it all better but when I don't have the wiring diagram for all the boards :( ( Just the on you gave me)
Wich part is it that is broken if it is? so i could get a better on...
And The YOC PW 3024 I made it better ;)
« Last Edit: April 19, 2014, 02:52:50 AM by SirFinland »
  •  9,376 9,376
« Reply #16 on: April 19, 2014, 04:41:29 AM »
I would check these components (circled red).
Thanks....It Was okay for 2 weeks.... What kind of a better board can i look at on Ebay? Name? Sort? So i could get one that works 1-5 years... Not weeks...
Thanks!
Finland
  •  9,376 9,376
Hi Finland,
I can't recommend anyone in particular but I think you should buy from those that offer support for their products and have a known track record.
Perhaps someone like CNC4PC http://www.cnc4pc.com/Store/osc/index.php may have a suitable product.
