Hello Guest it is October 11, 2026, 09:33:38 AM
Author Topic: Mach Blue Probing by Big-Tex - new version 3.4 avaliable soon  (Read 225180 times)
Re: Mach Blue Probing by Big-Tex - new version 3.4 avaliable soon
« Reply #10 on: March 31, 2014, 06:59:14 PM »
Officially out.
Thank you alll for great support
Thomas
Thank you for your support in developing better cnc experiance.
 Scan my avatar with smart pnone .......
http://big-tex.tk/
« Reply #11 on: April 05, 2014, 04:03:44 PM »
I'm having trouble loading the screen set.  It's as if the JPG is not loaded or found.
« Reply #12 on: April 05, 2014, 04:10:44 PM »
please let me know where is your mach 3 installed?
C://mach3
Thomas
http://big-tex.tk/
« Reply #13 on: April 05, 2014, 04:14:36 PM »
Keep in mind during install you need to indicate where mach3 is installed.
I do have youtube video showing installation process
https://www.youtube.com/watch?v=lVX537uj1cU&feature=youtu.be
Its is also good idea to have previous verion of my screen uninstalled as good measure.
Its been several years and I did not have all of my old filles to create installer as upgrade.
« Last Edit: April 05, 2014, 04:27:47 PM by big-tex »
Thomas
http://big-tex.tk/
« Reply #14 on: April 21, 2014, 10:07:22 AM »
I am having the same issue with my screenset.  All the files are in the correct location, loads but all I get is the black death.  I have tried this on two different machines and also tried different profiles to see if there was something in the profile that was messing it up.  Any suggestions for a fix?
Thank you,
JH
« Reply #15 on: April 21, 2014, 11:28:42 AM »
Shot me emails I will resend install files, just in case of corruption
Thomas
http://big-tex.tk/
Offline ZASto
  •  434 434
« Reply #16 on: April 21, 2014, 11:48:26 AM »
Hi Thomas,
can you send me your script for TC Zero Setup?
I'm using your latest public domain screenset, heavily modified for all the functions to be mm/inch, and found, just yesterday, that if the fixed plate is higher than material surface, tool is never reaching material for cutting.
10x
Make no mistake between my personality and my attitude.
My personality is who I am.
My attitude depends on who you are.
« Reply #17 on: April 21, 2014, 12:10:26 PM »
It should be cutting fine calculated offset will be positive #, if plate is below material it will be negative #.
If you refer to verions prior to 3.4 you need to do it using my site to get files.
Thomas
http://big-tex.tk/
« Reply #18 on: April 21, 2014, 11:39:24 PM »
issue fixed check your email
if something needs further rework let me know
Thomas
http://big-tex.tk/
Offline ZASto
  •  434 434
« Reply #19 on: April 22, 2014, 02:05:49 AM »
Thomas,
thank you for your kind offer, M'a Baker style :)
Will have to put my brain to overdrive again.
« Last Edit: April 22, 2014, 02:08:26 AM by ZASto »
