Mach Discussion => Mach Screens => Finished Screens => Topic started by: big-tex on March 14, 2014, 05:07:00 PM
Currently testing with no problems found
have a question about your probing program have you fixed the problem with retract.
I ask this as when I was using your z probing it quite often crashed into the table. I changed it to one I got from hosses web site and the problem went away.
the only differences was it included retract.
at what function/ part of program did ou have issues with retracting?
if I did not reff all home more than 25 mm / 1 inch above the work pieces it would crash straight down I have a very big machine that I don't always have the homing switches on or I just did not have enough hight left above the work pices to do it.
I have never had a problem since I changed the codes.
your screen set is very good that is the only problem I ever had with it.
new screen set that is about to release is ment for metric and imperial, it is critical you designate z max or z zero in machine coordinates, referencing z axis take care of that. New viideo that will be posted on youtube explains lot of your issues. Also I am creating website that users can directly send issues or concens that may come as posiible future upgrades.
TESTING UPDATE: currently running cycle of 1296 of tool change with no problems
videos
http://www.youtube.com/user/BigTexCNC
where can someone get the new version?
-Vetsen
One more YouTube video pending, list of keyboard shortcuts etc.
I am hoping end of the week. Unless I get more jobs in and those take priority.
New videos uploaded to you tube.
Credit for creating original Blue screen goes to MrBean and SantiniUK.
I have added tool zeroing functionality etc.
New verision is about to be released.
I am hoping this weekend.
new version is released !
Officially out.
Thank you alll for great support
I'm having trouble loading the screen set. It's as if the JPG is not loaded or found.
(https://dl.dropboxusercontent.com/u/82376106/Screenshot%202014-04-04%2003.10.14.png)
please let me know where is your mach 3 installed?
C://mach3
Keep in mind during install you need to indicate where mach3 is installed.
I do have youtube video showing installation process
https://www.youtube.com/watch?v=lVX537uj1cU&feature=youtu.be
Its is also good idea to have previous verion of my screen uninstalled as good measure.
Its been several years and I did not have all of my old filles to create installer as upgrade.
I am having the same issue with my screenset. All the files are in the correct location, loads but all I get is the black death. I have tried this on two different machines and also tried different profiles to see if there was something in the profile that was messing it up. Any suggestions for a fix?
Thank you,
JH
Shot me emails I will resend install files, just in case of corruption
Hi Thomas,
can you send me your script for TC Zero Setup?
I'm using your latest public domain screenset, heavily modified for all the functions to be mm/inch, and found, just yesterday, that if the fixed plate is higher than material surface, tool is never reaching material for cutting.
10x
It should be cutting fine calculated offset will be positive #, if plate is below material it will be negative #.
If you refer to verions prior to 3.4 you need to do it using my site to get files.
issue fixed check your email
if something needs further rework let me know
Thomas,
thank you for your kind offer, M'a Baker style :)
Will have to put my brain to overdrive again.
Works great, Thank you Thomas for the quick customer support. The big software guys should take pointers from you ;)
Thanks again, Now I got to learn how to use this cool tool.
Jay
your welcome
Sorry everybody servers were hit with attack. All resolved
Ok I am using new provider, website back up
If anyone has questions please send me email using my website
Hello, Im a newbie to the forum and hope this is the right place to post,
couldnt find anything under search on this issue
im running Big-tex Blue tool setter ver3.4 and just finding my way around it,
all seems good once I got past the - you have to set the tool change position Z or the "initial set up" is going to crash"
the problem im having is that anytime i click a button on any screen it disappears, it will reappear if i refresh the screen (minimize then maximize mach 3)
doesn't do this on the normal mach3 screen
running Windows 10 on an I5 machine, any ideas how to fix this ?
many thanks
example attached (machine coordinates button)
PM sent
is the big tex screen set still available? if so, where?
thanks,
matt
I don't know what happened with Thomas,exchanged a couple of e-mails withhim, but he did not fix his page :(
I've bought his screenset and I know where it is still obtainable, but it would be unfair to share that location.
Send Thomas an e-mail, will provide you his address through PM
Sorry I would like to download this screen set but the Link on the Artsoft download transfer me in another site...and if I would like to do the same on the other one blue it can't append..How I have to do the download?
Anybody have a working link to the latest version of this screenset?
This is a link to the version that I use.
It used to cost $20, so if anyone wish to use it, can send Thomas the $20 by PayPal.
https://drive.google.com/file/d/0B0cgFjjHPRt7bEwwNjEtYXZHd3M/view?ts=58c16811
I sent you a PM sir if you could pls check it. Thanks :)
As the gdrive link is non functional, here is another that will stay for much longer.
Do not be afraid of russian language, I use that cloud service as it is cheap.
https://cloud.mail.ru/public/6mtg/2WYpmeTvD
Where could I download this screenset. The link to big tex does not work. (Can not be found) Or can anyone recommend a screenset that can use "triple edge finder"?
Read above
