Hello Guest it is November 13, 2026, 10:01:13 AM
Author Topic: Lathe screen and mill screen differences. Why?  (Read 15472 times)
« on: March 11, 2007, 07:56:30 AM »
I wiill start by sying I have never used a  CNC lathe but am nearing finishing my lathe retrofit. I dont really like the way the lathe screen is set out, more than likely because I am used to the mill screens and just take bad with the different way of working/layout.
 Is there any reason that the lathe screens are totally different setup from the mill screens? IF not then I will modify my mill screen to suit the two axis of the lathe.
ynneb
Re: Lathe screen and mill screen differences. Why?
« Reply #1 on: March 12, 2007, 04:53:21 PM »
The only difference is that it was designed by a different person, and that is how they liked it.
Go for it, your design will be fine.
« Reply #2 on: March 12, 2007, 05:25:50 PM »
Already done it , not sure if its fine though, think it will need a lot of tweaking as I get into the swing of using a lathe (pun inended ;)  )
Will probably find I end up using a screen similar to your good friend Steves ;)
ynneb
« Reply #3 on: March 12, 2007, 06:02:52 PM »
Now Now :)
If it works for you then it's fine.
« Reply #4 on: March 13, 2007, 02:39:32 PM »
:D
« Reply #5 on: March 14, 2007, 07:52:47 AM »
Hood Make a new Screen, I have a hard time using that one too...
www.newfangledsolutions.com
www.machsupport.com
« Reply #6 on: March 14, 2007, 03:41:06 PM »
Have it made but will have to modify it as I get used to my lathe and find my way of working, that is if I ever get the lathe finished ;)
« Reply #7 on: March 14, 2007, 03:46:54 PM »
You'll get it Hood. I'm sure it will be as nice the mill too. You do good work. ;)
