Hello Guest it is November 02, 2026, 02:09:32 PM
Author Topic: Moving Mach3 license  (Read 32225 times)
Offline markn
  •  29 29
« on: March 13, 2014, 08:59:10 PM »
Gentlemen,
I have had a licensed copy of Mach3 on my computer for a number of years. I now would like to move the software and license to the PC that I am using for my Bridgeport retrofit. How do I accomplish this?
Re: Moving Mach3 license
« Reply #1 on: March 13, 2014, 09:15:29 PM »
Just copy the file license.dat to the new machine.
« Reply #2 on: March 13, 2014, 09:29:53 PM »
It's Mach1Lic.dat
« Reply #3 on: March 13, 2014, 09:31:03 PM »
Your Mach3 license is called   Mach1Lic.dat  and it is in your original Mach3 folder - just copy and paste / transfer it to your new Mach3 folder and away you go (no need to purchase a new license).
If you wish, you can download the latest version of Mach3 from here http://www.machsupport.com/software/downloads-updates/
(originally contributed by our good friend Tweakie)
Russ
« Reply #4 on: March 13, 2014, 09:32:57 PM »
Quick draw McGerry  :D
Russ
Offline markn
  •  29 29
« Reply #5 on: March 13, 2014, 09:33:39 PM »
Thanks for the replies. When I copy the mach folder SETUP.EXE will not transfer over.
Offline markn
  •  29 29
« Reply #6 on: March 14, 2014, 09:11:29 AM »
Hi
Has anyone experienced the issue with copying the setup.exe folder.
On my PC the folder appears faded compared to the folders in the Mach3 directory. I have the thumb drive plugged in paste the copy to it and I can see it. But when I transfer to the new PC the setup.exe file is not on the thumb drive..........
« Reply #7 on: March 14, 2014, 10:36:05 AM »
You shouldn't need any setup.exe file.
« Reply #8 on: March 14, 2014, 11:22:50 AM »
This is a fresh install on the BPort PC .. right ?
Download the version you prefer, save it then run it on your new pc. (from earlier link/FTP site)
Then add your .lic, custom screens, macros, brains, plugins and anything else from the old pc.
I don't think you can just copy the M3 folder to the new pc.
I could be wrong (again) though,
Russ
Offline markn
  •  29 29
« Reply #9 on: March 15, 2014, 05:56:43 AM »
Hi guys.
I successfully downloaded and installed mach to the new PC. Now when I open mach the PC freezes. Any advice?
