Hello Guest it is November 04, 2026, 10:06:01 AM
Author Topic: Mdi question  (Read 11455 times)
Mdi question
« on: March 07, 2014, 01:03:05 PM »
Hi all,   quick question.   When I input say,  X2 F10 I was expecting to move 2 in X at a feed of 10.  I get the email expected 2 in X but feed rate does not change.   What am I doing wrong?
Sent from my Galaxy Nexus using Tapatalk
Re: Mdi question
« Reply #1 on: March 07, 2014, 01:29:04 PM »
You may be still in the modal G0.
Enter G1 X2 F10 and see what you get.
G1 is modal also.
Just a guess,
Russ
Re: Mdi question
« Reply #2 on: March 07, 2014, 01:39:26 PM »
Thanks.  I bet that is it because I swear it worked for me in the past.   Is there a proper entry method to be sure it always works?  If both are modal, do I just toggle it each time?
« Last Edit: March 07, 2014, 01:58:30 PM by Overloaded »
Re: Mdi question
« Reply #3 on: March 07, 2014, 01:56:58 PM »
Unless I'm absolutely sure which is active, I will include it every time when MDIing.
Due to my inexperience  ::), my cnc is full of surprises  :o ... so I try to keep them to a minimum. :)
A rapid, when unexpected can raise the heart rate considerably.  ;D
Russ
Offline Fastest1
  •  920 920
  • Houston, TX
Re: Mdi question
« Reply #4 on: March 07, 2014, 10:36:54 PM »
I do it as Russ does too, if hand coding line by line it is always a G0 or G1.
