Hello Guest it is September 15, 2026, 10:35:51 AM
Author Topic: CNC 3040 and Pocket tool path...  (Read 15124 times)
« on: March 01, 2014, 12:54:59 PM »
I'm having problems with my cnc3040 and VCarve pro 6.
When I do a pocket with a word in it so the first 0.5mm is ok but when it will start on 1.0mm layer so the letters are about 0,5mm to the right or left.
All setting are like the should be and nothing is loose on the machine!
Can some on please help me whit this and give mi some goood tips!!!
Thomas
Re: CNC 3040 and Pocket tool path...
« Reply #1 on: March 01, 2014, 03:36:44 PM »
Looks like you are losing steps on X axis. Reduce the Vel and Acccel on that axis and see if it helps. Also check for binding in that axis.
« Reply #2 on: March 05, 2014, 09:57:35 AM »
Hi.....
I'm getting crazy... ;)
When I'm doing a pocket that is 120mm x 70mm it is okay I have less acc on X.
But when im doing a pocket with a text soit looks like this
And the settings i Have is
X 400 2000 160
Y 400 2000 200
Z 400 700  100
What is wrong? is it the Feed rate or plunge rate? Or something else??
Thanks!!!!!
« Reply #3 on: March 06, 2014, 01:58:21 AM »
Have you checked for binding in the axis? Have you tried reducing accel and Vel?
« Reply #4 on: March 06, 2014, 02:56:48 AM »
Yes I have done everything... but no help so far :(
Do you know what could be the right setup for it? All axels are okay...
« Last Edit: March 06, 2014, 03:00:03 AM by SirFinland »
« Reply #5 on: March 06, 2014, 05:28:22 AM »
You would seem to be losing steps in the X axis so if reducing the accel/vel does not help and you have checked that there is no binding in that axis then the next thing to try is swapping drives around.
« Reply #6 on: March 06, 2014, 05:34:32 AM »
Thanks! Sorry I'm not so good at this English I'm a Finn ;)
What do you mean whit this "swapping drives around"
Thanks!!
Thomas
« Reply #7 on: March 06, 2014, 01:01:40 PM »
I mean try swapping the stepper drive on X axis with the one on Y axis. If the problem stays with X then the drive is not the problem.
« Reply #8 on: March 06, 2014, 01:11:59 PM »
Okay so I will change places for the steppers motors.
