Hello Guest it is November 22, 2026, 03:11:46 PM
Author Topic: mpv has invalid port and pin settings for the A input. port=3, pin-1 in mach3  (Read 32310 times)
 I had Jeff @Soigeneris update my control box from USB to Ethernet as I kept getting an error for the smooth steppers and I could not get it fixed.
I HAVE NO PROBLEM WITH JEFF, I'd just rather not bother him as its the weekend.
I'm getting this error msg....mpv has invalid port and pin settings for the A input. port=3, pin-1
When looking at the ports and pins it does in fact say that for both the in and out. I know thats not right but I have no idea what should it be ?
Estop is port-1, pin-14 fwiw
Is port 3 set for pins 1-9 as Inputs? If not then you will likely get that message as 1-9 are Outputs by default. You can check by looking at the Config, from Plugin Control menu.
 Thank you.
Arn't those for servo motor drives ? I'm not using them so I'm pretty sure I don't need them. I turned them off.
 Now I get a PWM error. I've tried to change it but it seems to make no difference.
« Last Edit: March 01, 2014, 08:00:16 PM by TCustoms »
First thing, when you say MPV are you actually meaning MPG? If not what does MPV stand for?
Should have been MPG,  I have fat fingers. :(
Ok a MPG is a Manual Pulse Generator, it is used for moving the axes manually.
 If you do not have one connected then go to Config menu then Ports and Pins then Encoder/MPG page and disable the MPG.
 Yes Sir, as I said above, I turned them off.
 I now have a PWM error.
 It was always there I just didn't ask about it at the time so I didn't muddy the waters.
Ah ok thought you meant that turning off the MPG made the PWM error appear.
PWM is a spindle error, how is your spindle set up? What kind of spindle controller are you using?
 Sorry about the confusion. Its a TAIG mill
 Here is a pic of the spindle page. When I press F5 I get the error msg,  PWM
« Last Edit: March 02, 2014, 01:16:42 PM by TCustoms »
Offline Fastest1
  •  920 920
  • Houston, TX
In spindle set up, uncheck PWM, and check step/dir motor, apply, ok. That is how mine is set up. Mine is a Sherline with Homanns speed controller. It will either work or it wont. If it doesnt, change it back and wait for Jeff.
