Hello Guest it is November 13, 2026, 06:22:06 PM
Author Topic: Pokeys56 and Smoothstepper (ethernet)  (Read 51426 times)
Offline tantan
  •  130 130
Re: Pokeys56 and Smoothstepper (ethernet)
« Reply #10 on: March 17, 2014, 09:51:35 AM »
Neoto explained me that this cannot be asmoothstepper issue. Within a few weeks i will test my pendant with the sro funtion in combination with a cslabs controller. I will report my findings here,
Tnx tantan
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #11 on: March 17, 2014, 11:45:15 AM »
Tnx tantan
I explained to you that this can not be PoKeys's issue if Smoothstepper is crashing, not the other way around.
Offline tantan
  •  130 130
« Reply #12 on: March 17, 2014, 11:56:37 AM »
hi yes, i am sure you are right. but i want to do the test to convince the smoothstepper guys!
« Reply #13 on: March 17, 2014, 01:59:41 PM »
this evening I had only time to verify that disabling the SRO by deactivating the encoder at pin 5 and 6 will lead to a smooth run of an example g-code.
Even with the spindle at maximum revolutions I had no longer any issues. I tried that several times.
That leads to the question whether filtering of the encoder inputs could improve ruggedness against radiated noise from the spindle driving circuit?
I will try it tomorrow evening and report the results here.
« Reply #14 on: March 18, 2014, 03:19:05 PM »
In the meantime I've added 1k resistors and  10nF capacities to pin 5 and 6, the inputs of the encoder for SRO, but to no avail.
Wolfgang
Offline tantan
  •  130 130
« Reply #15 on: March 18, 2014, 03:54:30 PM »
I do not think this is a hardware issue. According to neoto  the plugin of SS is causing the trouble
« Reply #16 on: March 18, 2014, 04:46:07 PM »
I think I've have to agree with you. I hope this issue could be cleared by an update of the plugin.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #17 on: March 19, 2014, 12:06:19 AM »
I overlooked your post, tantan, that SS plugin produces an error only after these glitches. So, please confirm - SS plugin does not crash immediately, but after there are glitches on the SRO value.
Offline tantan
  •  130 130
« Reply #18 on: March 19, 2014, 02:15:00 AM »
Yes, that is exactly what i notice!
« Reply #19 on: March 19, 2014, 03:24:48 AM »
Hi NeoTo,
I experience exactly the same effect, but with an Smoothstepper USB. If the encoder of the pendant, based on the PoKeys56U, for SRO at pins 5 and 6 is disabled, there are absolutely no problems with the smoothstepper. The fault with the smoothstepper, as mentioned by TanTan, occurs only with the encoder for SRO set active, even with RC- filters attached to the inputs. There is no difference whether you make a move of an axis with the MPG or by running a job.
With the spindle switched off, it doesn't matter whether the encoder for SRO is active or not.
Wolfgang
