Hello Guest it is November 13, 2026, 09:47:19 AM
Author Topic: dir pulse length  (Read 11156 times)
dir pulse length
« on: March 09, 2007, 12:23:41 PM »
Hello.
What does dir pulse mean  in the motor tunning setting? Is it time between dir output change and step impulse?
thanks for reply
michal
Re: dir pulse length
« Reply #1 on: March 09, 2007, 12:34:11 PM »
I would imagine that it is simply the length of time of the direction pulse.
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
« Reply #2 on: March 09, 2007, 03:25:51 PM »
That is a good question..  I am not sure what that is there for any way. The direction pulse is sort of a misnomer. The direction pulse doesn't really pulse, it just goes high for forward and low for reverse.  I suppose if you were going back and forth 2 stepper pulses on the step then you might need to add some time but that would be a very rare instance.   I wonder if it has something to do with macx nc mode or something..
Brian??
Chad
« Reply #3 on: March 12, 2007, 10:29:42 AM »
I've tried to change the value and look at the signal with oscilloscope. But nothing happens. There is some time before step pulse (20us) is it possible to change it?
