Hello Guest it is October 05, 2026, 06:27:46 PM
Author Topic: Encoder as feed rate override?  (Read 19657 times)
« on: February 22, 2006, 03:32:10 PM »
Hi, Could I set up an encoder or mpg input to increase and decrease the
feed rate override?
Roger
Re: Encoder as feed rate override?
« Reply #1 on: February 23, 2006, 04:48:07 AM »
no but you can use a pot with modio or a PLC...
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: February 23, 2006, 07:27:12 AM »
Hi again!
Ok, but could I have two usb joysticks? One for jogging the axis and
the other to set override and maybe jogspeed and so on.
Roger
« Reply #3 on: February 23, 2006, 06:12:02 PM »
I don't think so :(
www.machsupport.com
« Reply #4 on: February 24, 2006, 07:10:16 AM »
Brian, doesn't this quote from the Mach2 customizing manual contradict you here.
"It is also possible to connect an encoder (typically low resolution like those used as "digital potentiometers" in hi-fi and video equipment) and to generate a given scancode for each "click" in the clockwise direction and another scancode for each counterclockwise click."
Doesn't this say that you can use an encoder for feedrate override?
« Reply #5 on: February 24, 2006, 08:07:47 AM »
This is like using the input as a button.... there are a few that have done that in the past but I don't know how it worked.
www.machsupport.com
