Hello Guest it is November 22, 2026, 11:09:39 PM
Author Topic: Cannot get homing and limits to work  (Read 15390 times)
« on: March 08, 2007, 05:39:51 PM »
I am using two inputs. One for x++ and x-- with switches in series and the other for the y axis. The x ++ and y ++ limits double as home switches. The problem is when I home the y axis hits the limit and stops then the x axis does the same. I then trip on a limit switch triggered. Neither axis comes off the switch. Second problem is limit overide does not work. When I hit the switch the red led blinks and goes out. The autolimit over ride does not work. The green led comes on but nothing happens. I am tripping on a logic high signal. The machine operates fine when cutting.
Re: Cannot get homing and limits to work
« Reply #1 on: March 12, 2007, 10:31:52 PM »
Have you set a denounce? Sounds like you need to have about 1500 to start with
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: March 13, 2007, 06:46:48 PM »
What is a denounce and how do I set it?
« Reply #3 on: March 13, 2007, 07:23:56 PM »
You set this under the General configs and I think it is in the upper right
www.machsupport.com
jalbro
« Reply #4 on: March 13, 2007, 07:26:58 PM »
There it is!
The documentation should be updated to reflect this.... according to the PDF on the website where is a "logic" config screen.
A side question... should an optical switch need debouncing?
Thanks!
-Jeff
« Reply #5 on: March 13, 2007, 07:53:05 PM »
Yes if there is any mechanical bounce at all in the system the computer will pick it up...
www.machsupport.com
« Reply #6 on: March 14, 2007, 05:40:20 PM »
That did the trick. Thanks a lot for the help.
