Hello Guest it is November 13, 2026, 04:37:00 AM
Author Topic: How to make a Pocket RIGHT!!  (Read 37456 times)
Re: How to make a Pocket RIGHT!!
« Reply #20 on: February 09, 2014, 06:00:16 PM »
attach your code and your xml and maybe the problem can be found.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #21 on: February 09, 2014, 07:01:46 PM »
I am having problems with pockets as well.drew a design in vecrtic aspir was supposed to cut a circle to 51 mm and 4.5 mm deep depth came out fine but circle is only 46 mm dia and should be 51.I have calibrated all the axis and they cut to the right length and z axis raises and lowers to the right heights don't know whats wrong does anyone have any ideas
Regards \Kevin
 Is your tool diameter correct?
 Not being familiar with your CAD/CAM, is your offset correct for the direction of travel? I know in BobCad I usually have 3 choices, to the right, left or on the line. Those would all make a difference in the widths only and not the depth.
« Reply #22 on: February 09, 2014, 08:01:18 PM »
yeah as far i i know it is correct i have three choices
1. outside the line
2 on the line
3 inside the line
 mine is set to inside the line
« Reply #23 on: February 09, 2014, 08:09:13 PM »
Try cutting in the opposite direction and see if the size changes. It could very well be machine or tool deflection.
« Reply #24 on: February 09, 2014, 08:46:46 PM »
will give it a try thnx
