Hello Guest it is November 13, 2026, 09:37:32 AM
Author Topic: Breakout boards as pictured in Mach 3 guide  (Read 14262 times)
Will
« on: March 07, 2007, 01:45:49 PM »
I'm new to this type of project and need to get some more clarification before I move forward.
I am moving closer to building/modifying one of our old Apple based CNC mills. I want to drive it using the Mach 3 software. In the users guide it says I should use a good  breakout board. It pictures 3 but does not list any manufacturer. I am runnning 3 slo-syn syncronous stepper motors. 1. Do I need a parallel port for each motor or are different pins assigned to different motors?  2. Where do I find the proper breakout board for my motors?
Thanks for any help provided
Re: Breakout boards as pictured in Mach 3 guide
« Reply #1 on: March 07, 2007, 02:46:01 PM »
Any breakout will do, I have used PMDX122 and it is a nice board and reasonably priced. Also have a CNC Building blocks one in the lathe I am presently retrofitting, its a bit dearer but has some very nice functions but they may not be of use to you.
 As for parallel ports you only need 1 for up to 4 axis but can add another if you require more inputs/outputs for other functions.
« Reply #2 on: March 07, 2007, 02:59:01 PM »
« Reply #3 on: March 07, 2007, 03:41:06 PM »
Also, click on the links tab above, look in electronics. Lots of suppliers there.
out**cold
« Reply #4 on: March 11, 2007, 06:32:10 AM »
how do I add more parallel ports ? I need more inputs.
« Reply #5 on: March 11, 2007, 07:27:25 AM »
only possible to have two parallel ports, if you only have one at the moment you just need to get yourself a PCI parallel port. If you already have two then there are other ways to get more I/O, one route is a PLC over Modbus.
