Hello Guest it is September 03, 2026, 01:34:07 AM
Author Topic: motor movement  (Read 13364 times)
motor movement
« on: January 27, 2014, 09:55:31 AM »
I have been using Mach 3 for a while now and my computer crashed. I reconnected another computer that I had been using to try my programs (simulating). I lost all my inputs and output configurations but that is not the real problem. I have gone thru the setup procedures and should have enough information for motor movement but do not. I can hear them react to commands but no movements. I do have them enabled in Ports an pins. Please help.
Bill
Re: motor movement
« Reply #1 on: January 27, 2014, 10:29:31 AM »
you'll HAVE to edit motor tuning in gen conf.
i had that where they wanted to move.
good luck
Kenneth
Re: motor movement
« Reply #2 on: January 27, 2014, 12:56:54 PM »
I have hade my motor tuning all over the place and still no movement
Re: motor movement
« Reply #3 on: January 27, 2014, 01:08:34 PM »
as i said....you can't "guess"
and you may need to up/lower your kernal speed
in ports and pins.
Kenneth
Re: motor movement
« Reply #4 on: January 27, 2014, 01:16:56 PM »
kernel speed did not help my problem
Re: motor movement
« Reply #5 on: January 27, 2014, 01:30:55 PM »
can you try putting a check mark by Sherline 1/2 Pulse mode
in ports and pins.
Kenneth
Re: motor movement
« Reply #6 on: January 27, 2014, 01:37:10 PM »
tried that and restarted the software and no change
Re: motor movement
« Reply #7 on: January 27, 2014, 01:39:19 PM »
then i'm at the end of my knowledge.
i do wish you luck !
Kenneth
Re: motor movement
« Reply #8 on: January 27, 2014, 01:40:34 PM »
thanks for trying...
Bill
