Mach Discussion => FAQs => Topic started by: 60hdrider on January 27, 2014, 10:55:31 AM
I have been using Mach 3 for a while now and my computer crashed. I reconnected another computer that I had been using to try my programs (simulating). I lost all my inputs and output configurations but that is not the real problem. I have gone thru the setup procedures and should have enough information for motor movement but do not. I can hear them react to commands but no movements. I do have them enabled in Ports an pins. Please help.
Bill
you'll HAVE to edit motor tuning in gen conf.
i had that where they wanted to move.
good luck
I have hade my motor tuning all over the place and still no movement
as i said....you can't "guess"
and you may need to up/lower your kernal speed
in ports and pins.
kernel speed did not help my problem
can you try putting a check mark by Sherline 1/2 Pulse mode
in ports and pins.
tried that and restarted the software and no change
then i'm at the end of my knowledge.
i do wish you luck !
thanks for trying...
Bill
