Hello Guest it is November 13, 2026, 09:36:35 AM
Author Topic: Cable Ducts  (Read 10043 times)
Offline kolias
  •  1,165 1,165
Cable Ducts
« on: January 17, 2014, 11:31:05 AM »
I use 1" x 1" cable ducts in my control panel and although they make the wiring much better looking and easier to run I have a heck of a time to remove their covers after I install them.
When I first installed the ducts, I put the covers on just to see how it looks / works and when I tried to remove the covers I had to use pliers to pull them off (I'm glad I had no wires inside)
For now the covers are off in case I want to add / revise the wiring but I wonder is there a trick or method to easily snap off the covers?
Nicolas
Offline mc
  •  384 384
Re: Cable Ducts
« Reply #1 on: January 17, 2014, 12:43:55 PM »
It depends on the style. Some just require brute force, others you need to push the sides in before pulling the cover off.
Re: Cable Ducts
« Reply #2 on: January 17, 2014, 12:53:31 PM »
Push the cover hard towards one side, then lift on that side. Alternately pull on the cover on one corner then run a finger under the cover popping the base fingers loose as you go. Small shallow ones like you are using are the toughest. Deeper ones are much easier.
Offline kolias
  •  1,165 1,165
Re: Cable Ducts
« Reply #3 on: January 17, 2014, 02:31:53 PM »
Thank you both, interesting
Nicolas
