Hello Guest it is November 18, 2026, 02:00:04 PM
Author Topic: Resetting X & Y alignment  (Read 8851 times)
« on: January 09, 2014, 09:02:41 PM »
I need to make several parts with the same hole design.
My part is 6" x 12" so I cut a pocket the part will fit in so I only need 2 small clamps to hold it down.
Problem is I jogged the x axis by accident so now the holes are not correct. I do not have homing switches.
Is there any way I can reset X&Y to drill the holes correctly without cutting a new pocket & starting over?
Thanks  :-[
Re: Resetting X & Y alignment
« Reply #1 on: January 10, 2014, 02:07:02 AM »
Normally you would use an edge finder and just touch off a known point in X and Y then set the DROs in Mach accordingly. Depending on how accurate you need things, even touching off with the cutter and a feeler gauge may be good enough, remembering of course to allow for the radius of the cutter when entering the position into Machs DROS.
« Reply #2 on: January 10, 2014, 04:00:53 AM »
I use a touch plate macro with a piece of aluminum angle as the plate.  This makes finding edges very easy, quick, and repeatable.
John Chamnplain
