Hello Guest it is October 24, 2026, 03:30:04 PM
Author Topic: Soft Limit Problem  (Read 66811 times)
Offline rufan
  •  38 38
Re: Soft Limit Problem
« Reply #30 on: January 25, 2014, 02:30:16 PM »
Yes that's totally understandable.
If CS-Lab updated there user manual I won't had this problem, or maybe I am a little blind :)
I will ask CS-Lab when the updated manual of the new plug-in is ready, because there is some new stuff in the new plug-in.
Thanks for all your support Hood.
« Reply #31 on: January 25, 2014, 02:41:50 PM »
I think the manual is low priority, especially with them working on Mach4 Plugin.
 I am just glad their hardware works as well as it does as it is the best I have used with Mach and was basically everything I had hoped and dreamed and even asked other people to make.
Offline rufan
  •  38 38
« Reply #32 on: January 25, 2014, 02:52:05 PM »
I can confirm, this is the best Hardware I ever used.
Hardware is not impressed of interference just fantastic.
Very very stable, until now no hangs and no crashes no lost comms.
The pulse-train is fantastic, so good that I was able to increase my axes speeds.
Even Milling Parts with above 30k lines it works fantastic.
CS-Lab did a very good job, and I can recommend this hardware to anyone who is going to retrofit.
Now hopping Mach4 is coming very soon.
Offline rufan
  •  38 38
« Reply #33 on: January 29, 2014, 10:52:02 AM »
Mail reply from CS-Lab
Dear sir,
I made some tests and I have found that CSMIO plugin require small improvement because the "Set Axis to "0" on reset" function should have nothing to do in your case.
Our developers will remove that issue very soon.
I'm sorry for any inconvenience and the same thank you for helping us improving our product.
« Reply #34 on: January 29, 2014, 12:06:41 PM »
That  is good to hear :)
