Hello Guest it is October 24, 2026, 03:30:23 PM
Author Topic: Soft Limit Problem  (Read 66812 times)
Re: Soft Limit Problem
« Reply #20 on: January 18, 2014, 01:52:37 PM »
Also noticed a strange thing, the video shows that its in Demo mode, are you running Demo or do you have a licence?
Offline rufan
  •  38 38
« Reply #21 on: January 18, 2014, 02:04:00 PM »
Yes I have a license, but because I removed Mach3 completely I forgot to put the license back.
But this do not have affect on this problem. Before removing Mach3 I had the same problem I took the Video after new fresh install.
Offline rufan
  •  38 38
« Reply #22 on: January 22, 2014, 04:35:31 AM »
Hood,
Did you try the C-Axis on your machine?
« Reply #23 on: January 22, 2014, 01:03:01 PM »
Can you attach your xml please so I can have a look over it.
« Reply #24 on: January 23, 2014, 06:27:49 AM »
I have just enabled C in Ports and Pins, Motor Outputs.
Changed the script in my RefAll button to include the C axis.
Homed the machine and it jogs fine via the MPG, via the keyboard and also moves fine via MDI. and I even tried disabling and re-enabling soft limits.
Offline rufan
  •  38 38
« Reply #25 on: January 23, 2014, 02:04:43 PM »
Hood,
Fantastic that it works on your machine, that means there must be a setting wrong on my machine.
Witch Mach3 & CS-Lab Plugin version are you using?
Here is my XML
Offline rufan
  •  38 38
« Reply #26 on: January 23, 2014, 02:05:22 PM »
XML File
« Reply #27 on: January 23, 2014, 03:29:35 PM »
I am using ver 057 I think and the latest plugin.
I tested this on the Chiron that uses the IP-A controller.
Offline rufan
  •  38 38
« Reply #28 on: January 25, 2014, 04:13:18 AM »
I have found the problem. Fixed and it is working fantastic.
The problem was actually very simple.
In CS-Lab Plugin menu> submenu "Special Functions" > tab "Other" the "Set Axis to "0" on reset" was not enabled.
« Reply #29 on: January 25, 2014, 05:14:16 AM »
Ok that is a setting for IP-S and M and it is one you can use with IP-A but really shouldnt as you have encoder feedback and if you did that it would mean you have to re-home each time you take Mach out of reset.
For the IP-S and M however that is really what you need to do as there is no feedback.
