Hello Guest it is November 13, 2026, 07:10:33 PM
Author Topic: M6start  (Read 10605 times)
M6start
« on: January 06, 2014, 09:13:19 PM »
I have designed and built a 3 axis cnc router and am adding a tool changer.  I have 3 output pins available as the tool changer has 3 routers mounted on 3 lineal ways controlled using relays/ pneumatic cylinders to drop the correct router in position.  So tool 1. Tool 2. Tool 3
Each cylinder is controlled by a separate signal so pin 14 sends 5 vdc to the tool changer causing tool#1 air cylinder to drop, router to come on, and a G53 to center the X &Y axis to the appropriate position to achieve Z0
Same with pin 16 for tool 2 and pin 17 for tool 3
I need to know how to proceed with making this work using Mach 3 M6start - end using Marco's
I haven't done any programming using Marco's but am a quick learner...
Please help!!!
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: M6start
« Reply #1 on: January 07, 2014, 11:47:50 PM »
Hi Mike,
I have sent you a PM.
Graham
Re: M6start
« Reply #2 on: January 10, 2014, 12:05:39 PM »
I'm getting a (Scripter compile error) when I test this script and also when I attempt to run it.  Can you help?
I have my tool changer built, wired and ready!!!
Thanks for your help
Re: M6start
« Reply #3 on: January 10, 2014, 07:52:28 PM »
Sorry  Also a Symtax error with the Scripter compile error
