Hello Guest it is November 22, 2026, 03:01:25 PM
Author Topic: Optical Registration Mark Reading With Mach3  (Read 76299 times)
Re: Optical Registration Mark Reading With Mach3
« Reply #30 on: March 28, 2014, 07:10:35 PM »
Doh!  I just found this sensor which completely eliminates the need for the Arduino.  This provides a stand alone solution for registration mark detection.  Now we can just work on the VB!  This should be easy to wire in as a probe.  Does anyone have some examples of calculating an arc tan in VB and setting the G68 coordinate system rotation from a script?
« Reply #31 on: March 29, 2014, 10:31:56 PM »
ATN (arc tangent) is covered in the "Cypress Enable for Mach" manual , page 44
« Reply #32 on: March 29, 2014, 10:53:33 PM »
How would i then set the g68?
« Reply #33 on: March 30, 2014, 07:03:39 AM »
I'd  provided how to set the g68 in the file that was posted to your other thread.
http://www.machsupport.com/forum/index.php/topic,26758.msg189574.html#msg189574
Call SetOemDro (118,NewAngle)
OEMDRO was added to screen with machscreen. To show me what it was set too. As if it is anything other than zero the Axis X Y DRO's values turn red.
The sensor you used before does not need the Arduino to work, it just needed a 12 volt DC supply, as it incorporated a SPDT relay.
You could then provided the 5 volt source at the relay.
Though it does a poor job of detecting a thin line and lighting the area has to be extremely controlled to be accurate and repeatable.
Using a wide line to get it to work well, makes me suspect its precision at the ability to find the true corner of the scanned probing routine.
Offline Bill_O
  •  616 616
« Reply #34 on: June 06, 2016, 04:32:24 PM »
i made a camera that finds the registration marks and adjusts for distortion and rotation
« Reply #35 on: May 10, 2017, 12:31:32 PM »
Hi guys! Any news on this? Does anyone have a registration system up and running?
Offline Bill_O
  •  616 616
« Reply #36 on: May 10, 2017, 12:42:23 PM »
because it was for my work and i spent work time i can not give a lot of information.
attached is the script i used for finding the dots and rotating and stretching the file.
hope it is a help
« Reply #37 on: May 10, 2017, 12:46:43 PM »
Thank you! I really appreciate it! :-)
« Reply #38 on: July 13, 2020, 02:04:55 PM »
Judging from your post, this solution that my team and I have been working on probably fits your criteria: https://www.youtube.com/watch?v=dqFpI4t21Z8
Effectively, we use registration marks to re-align the generated G-code, allowing for a proper cut despite the material being rotated or distorted. Let me know if you have any questions, I'd be happy to chat about this feature.
