Hello Guest it is November 13, 2026, 05:19:13 PM
Author Topic: MPG problem  (Read 12242 times)
MPG problem
« on: January 04, 2014, 07:31:56 AM »
I have the following mpg problem with pokeys.
MPG/ pokeys is working fine in mach mill.
But i have also , with the same pokeys mpg pc , running a second profile.
And than the mpg is not working at all.
Offline NeoTO
  •  504 504
    • PoLabs
Re: MPG problem
« Reply #1 on: January 05, 2014, 11:10:23 PM »
Hi, boutje
Due to some restrictions, PoKeys plugin for Mach3 supports 1 profile.
Matevž
Re: MPG problem
« Reply #2 on: January 06, 2014, 01:55:50 AM »
Ok, but in the second profile everything in the pokeys setup is the same.
All the buttons are working fine only the mpg not.
Offline NeoTO
  •  504 504
    • PoLabs
Re: MPG problem
« Reply #3 on: January 06, 2014, 03:12:49 PM »
1. Did you enable MPG1 in port & pins configuration (there should be nothing setup in the fields for port and pin)?
2. What DRO is MPG mapped to in PoKeys configuration?
