Third party software and hardware support forums. => PoKeys => Topic started by: boutje on January 04, 2014, 08:31:56 AM
I have the following mpg problem with pokeys.
MPG/ pokeys is working fine in mach mill.
But i have also , with the same pokeys mpg pc , running a second profile.
And than the mpg is not working at all.
Hi, boutje
Due to some restrictions, PoKeys plugin for Mach3 supports 1 profile.
Matevž
Ok, but in the second profile everything in the pokeys setup is the same.
All the buttons are working fine only the mpg not.
1. Did you enable MPG1 in port & pins configuration (there should be nothing setup in the fields for port and pin)?
2. What DRO is MPG mapped to in PoKeys configuration?
