Hello Guest it is November 13, 2026, 12:39:55 PM
Author Topic: Rotational Soft Limits on A axis, once more, cannot be disabled.  (Read 55004 times)
Re: Rotational Soft Limits on A axis, once more, cannot be disabled.
« Reply #30 on: January 12, 2014, 05:10:37 PM »
I found a few things:
- The soft limit is actually handled in steps, with the range 2^31-1; -(2^31-1)
- the maximum in units is then (2^31-1) divided by "steps per".
(2^31-1 is 2147'483'647, or for simplicity 2147'000'000 a bit less.)
My example:
- 80'000 steps per revolution of 360 degrees (40:1 gear)
- 222.2222222 "steps per", steps per degree
- maximum soft limit is +9'663'676.412;-9'663'676.412, respectively +9'663'676;-9'663'676 , respectively +9'661'500; -9'661'500.
- maximum limit in revolutions is 26'843 revolutions of 360 degrees in the positive or negative direction. Respectively 26837 revolutions.
(The latter values are from the above mentioned 2147'000'000 maximum steps.)
Notes:
- Mach3 does its positioning in steps in signed 32-bit values. The DRO positions are calculated on the fly from the steps and "steps per". We see this, when we change "steps per" in the motor tuning.
- When values are entered as soft limits, higher than those calculated from 2^31-1, they make overflow into negative or arbitrary values, which is not always noticed by Mach3.
- I do not yet know what is the required precision of fractional "steps by" values. Obviously Mach3 truncates them to 10 digits.
- Of course these large values are only a problem with rotational axes (because they can rotate many times, far in steps), not with linear ones (that have limited travel in steps).
« Reply #31 on: January 14, 2014, 06:17:47 AM »
Surprise on Exiting Mach3: The values are saved not as entered, but rounded Up.  In one profile, I entered +9'661'500; -9'661'500 (from  2147'000'000). It gets saved as +9'662'000;-9'662'000 (<M3Max>9.662e+006</M3Max>). In another profile (mine, the IT), I entered +9'663'676;-9'663'676 (exact max values). It gets saved as +9'664'000;-9'664'000. On next launch of Mach3, I access Limits/Homing, and close it, it says Limit Max<Min. obviously 9'664'000 is over the exact maximum..
before exiting Mach3, the values are used as entered. On the next launch, the saved rounded up values are used.
Peter.
PS My sample milling layout from  see picture  is 470 turns. With a maximum of 26838 turns before soft limits, we could produce 57 pieces without re-zeroing.
« Last Edit: January 14, 2014, 06:22:15 AM by PeterF »
