Hello Guest it is November 14, 2026, 12:41:07 PM
Author Topic: Limits / Home Confusion  (Read 9812 times)
Offline kolias
  •  1,165 1,165
« on: January 03, 2014, 10:50:31 AM »
On the Y axis I have a limit switch (Home) at the plus side of the table on pin 13 and another switch on the minus side of the table (Limit) on pin 15. Also on the A axis I only have one switch (Home) at the plus side of the table on pin 12.
In the Ports and Pins, Input Signals tab, do I enable both the Y++ and the Y Home. or just the Home?
Same on the A axis, do I enable both the A++ and Home?
Nicolas
Re: Limits / Home Confusion
« Reply #1 on: January 03, 2014, 10:55:15 AM »
Assuming A is slaved to Y.
Y++ and Y Home on Pin 13
Y-- on Pin 15
A Home on Pin 12
Offline kolias
  •  1,165 1,165
« Reply #2 on: January 03, 2014, 11:30:34 AM »
Thank you Gerry, yes they are slaved and I will use your settings
Nicolas
