Hello Guest it is November 07, 2026, 10:38:36 PM
Author Topic: problem s in machining 2" hole  (Read 8790 times)
« on: January 01, 2014, 11:29:13 AM »
I'm cutting out 2" holes in AL sheet metal, the problem is the holes come out 2.125". I'm using a .125 bit, so I think the program is using the center of the bit for the cutting path. I'm very new at this, so any help would be nice. I was wondering if the is some type of setup in mach3 or lazycam that I missed, as I really don't want to change the hole size in the program to 1.875" to cut a 2" hole.
Re: problem s in machining 2" hole
« Reply #1 on: January 01, 2014, 03:29:50 PM »
It will be a setting in LazyCAM I would think. Dont use and never have so afraid I cant help with it.
« Reply #2 on: January 02, 2014, 06:36:42 AM »
