Hello
Guest
it is
October 24, 2026, 06:17:21 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach 3 issues, offsets for each pass about 0.5mm
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach 3 issues, offsets for each pass about 0.5mm (Read 14677 times)
Børge
22
on:
December 28, 2013, 07:14:42 AM »
Hi
Have a strange problem with Mach3
For every pass i makes it offsets the cutting patern with 0.5mm ??
Has this something with the motor tuning to do.
Børge
Logged
ger21
6,295
Re: Mach 3 issues, offsets for each pass about 0.5mm
Reply #1 on:
December 28, 2013, 07:33:08 AM »
Does it offset in one direction, or all directions? Can you post a pic of what it's doing?
Logged
Børge
22
Reply #2 on:
December 28, 2013, 08:03:29 AM »
Hi
It offsets in two directions
-X and -Y
Børge
Logged
ger21
6,295
Reply #3 on:
December 28, 2013, 08:26:46 AM »
Is the spindle perpendicular to the table?
Logged
Børge
22
Reply #4 on:
December 28, 2013, 09:58:04 AM »
Yes it is.
measured the Zaxis, and its 89.4 degrees to the table.
i will post a pictyre of what happends.
Børge
Logged
Børge
22
Reply #5 on:
December 29, 2013, 07:38:10 AM »
Here is a picture of the problem.
i tried to change the stepover, but dint do anything.
Could it be a motor tuning issue.
Børge
Logged
ger21
6,295
Reply #6 on:
December 29, 2013, 08:05:09 AM »
Try reducing the acceleration in motor tuning by 50%
Logged
Børge
22
Reply #7 on:
December 29, 2013, 02:45:57 PM »
Didnt help the issue
Børge
Logged
Børge
22
Reply #8 on:
January 02, 2014, 03:12:16 AM »
Hi guys, and thanks for helping.
It looks like i figured it out.
I reduced the stepping from full to half, and tried again.
This time it was ok.
Borge
Logged
Print
Pages:
1
Go Up
« previous
next »
