Mach Discussion => General Mach Discussion => Topic started by: Børge on December 28, 2013, 08:14:42 AM
Hi
Have a strange problem with Mach3
For every pass i makes it offsets the cutting patern with 0.5mm ??
Has this something with the motor tuning to do.
Børge
Does it offset in one direction, or all directions? Can you post a pic of what it's doing?
Hi
It offsets in two directions
-X and -Y
Børge
Is the spindle perpendicular to the table?
Yes it is.
measured the Zaxis, and its 89.4 degrees to the table.
i will post a pictyre of what happends.
Børge
Here is a picture of the problem.
i tried to change the stepover, but dint do anything.
Could it be a motor tuning issue.
Børge
Try reducing the acceleration in motor tuning by 50%
Didnt help the issue
Børge
Hi guys, and thanks for helping.
It looks like i figured it out.
I reduced the stepping from full to half, and tried again.
This time it was ok.
Borge
