Hello
Guest
it is
November 23, 2026, 11:43:55 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
.txt files
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: .txt files (Read 10525 times)
OB Cues
25
.txt files
on:
December 19, 2013, 11:23:11 AM »
I create all my gcode files with notepad and they all have .txt extensions. Can I have Mach3 see them when I choose the load file button?
RBC
ger21
6,295
Re: .txt files
Reply #1 on:
December 19, 2013, 11:43:08 AM »
When loading g-code, click the "File Type" dropdown and select .txt or "all files", and then open your .txt file. After you close and restart Mach3, it will only show .txt files.
BR549
6,965
Re: .txt files
Reply #2 on:
December 19, 2013, 11:43:44 AM »
When you LOAD a file select from the pop up box which extension you want to see or ALL to see everything.
(;-) DARN can't type fast enough
OB Cues
25
Re: .txt files
Reply #3 on:
December 19, 2013, 12:18:49 PM »
That's funny because that is what I do.
I always just drop down the box and select all files.
But, when I reopen Mach, it's always back the same way.
RBC
cncalex
244
Re: .txt files
Reply #4 on:
December 19, 2013, 12:56:12 PM »
hit load file.
then in the first lane ( filename ) type in *.txt and hit enter.
alex
Print
Pages:
1
Go Up
« previous
next »
