Hello Guest it is October 10, 2026, 05:47:36 PM
Author Topic: .txt files  (Read 10199 times)
.txt files
« on: December 19, 2013, 11:23:11 AM »
I create all my gcode files with notepad and they all have .txt extensions. Can I have Mach3 see them when I choose the load file button?
RBC
Re: .txt files
« Reply #1 on: December 19, 2013, 11:43:08 AM »
When loading g-code, click the "File Type" dropdown and select .txt or "all files", and then open your .txt file. After you close and restart Mach3, it will only show .txt files.
Re: .txt files
« Reply #2 on: December 19, 2013, 11:43:44 AM »
When you LOAD a file select from the pop up box which extension you want to see or ALL to see everything.
(;-) DARN can't type fast enough
Re: .txt files
« Reply #3 on: December 19, 2013, 12:18:49 PM »
That's funny because that is what I do.
I always just drop down the box and select all files.
But, when I reopen Mach, it's always back the same way.
RBC
Re: .txt files
« Reply #4 on: December 19, 2013, 12:56:12 PM »
hit load file.
then in the first lane ( filename ) type in   *.txt and hit enter.
alex
