Hello Guest it is October 23, 2026, 11:33:59 AM
Author Topic: Mach3 and Vcarve6 CNC3040  (Read 10703 times)
« on: December 01, 2013, 10:55:47 AM »
Is there any "right" settings for Vcarve 6 so it will work okay with Mach3 and a cnc3040?
Settings for Feed Rate and Plunge Rate and so on.....
Re: Mach3 and Vcarve6 CNC3040
« Reply #1 on: December 01, 2013, 11:05:18 AM »
Feed rates are dictated by the material your cutting, the tool your using, and the rpm the spindle is turning. It also has a little to do with trial and error to get the best results.
« Reply #2 on: December 01, 2013, 11:09:14 AM »
Thanks!
I have some problems to get the spindle http://www.youtube.com/watch?v=57xY94SnlCQ
  •  9,374 9,374
« Reply #3 on: December 03, 2013, 02:43:09 AM »
From your video it appears that your gantry is not parallel with your table. The following diagram may help.
