Mach Discussion => General Mach Discussion => Topic started by: SirFinland on December 01, 2013, 11:55:47 AM
Is there any "right" settings for Vcarve 6 so it will work okay with Mach3 and a cnc3040?
Settings for Feed Rate and Plunge Rate and so on.....
Feed rates are dictated by the material your cutting, the tool your using, and the rpm the spindle is turning. It also has a little to do with trial and error to get the best results.
Thanks!
I have some problems to get the spindle http://www.youtube.com/watch?v=57xY94SnlCQ
From your video it appears that your gantry is not parallel with your table. The following diagram may help.
