Hello Guest it is October 24, 2026, 06:23:42 PM
Author Topic: How do you Connect the Metal Braiding of a Cable?  (Read 14944 times)
Offline kolias
  •  1,165 1,165
« on: November 29, 2013, 09:07:26 AM »
I'm wiring my four stepper motors 18AWG shielded cables and I want to know how I ground physically the cable shields at the panel end.
When I cut the exterior plastic shell of each cable, there is under it the metal braiding and after there is the aluminum foil; do I ground only the braiding, the foil, both?
And how do you do this physically? Do I solder a piece of wire to the braiding / foil ?
Nicolas
Re: How do you Connect the Metal Braiding of a Cable?
« Reply #1 on: November 29, 2013, 10:06:06 AM »
Solder a short piece of stranded wire to the copper braid only.  The foil can be trimmed out of the way.
John Champlain
Offline kolias
  •  1,165 1,165
« Reply #2 on: November 29, 2013, 01:23:32 PM »
Thank you John
Was planning doing so but thought maybe there is a better way
Nicolas
« Reply #3 on: November 30, 2013, 06:06:09 PM »
^ That's how I've always done it on every sort of equipment I've worked on. For tidiness, pop a bit of self-adhesive heat shrink over the transition between the braid and the insulated wire tail ;)
Offline kolias
  •  1,165 1,165
« Reply #4 on: November 30, 2013, 08:52:28 PM »
Good point, makes for a better looking connection
Nicolas
« Reply #5 on: December 01, 2013, 12:32:12 PM »
I've used the heat shrink solder type butt splices for this. Just put the two ends into the splice and heat with a heat gun. Solder melts and tube shrinks at the same time. It looks very neat.
Offline kolias
  •  1,165 1,165
« Reply #6 on: December 01, 2013, 01:28:53 PM »
Don't know about this Gary but I will try to find out. Sounds a good idea
Nicolas
« Reply #7 on: December 01, 2013, 08:45:35 PM »
Forgot to mention, Home Depot has them
Offline kolias
  •  1,165 1,165
« Reply #8 on: December 01, 2013, 09:38:51 PM »
Thanks for the tip.
Just found them on HD site but they only have for 14, 12 and 10AWG. Will try elswhere because I need for 18AWG
Nicolas
