Hello Guest it is October 24, 2026, 10:49:54 AM
Author Topic: New download will not run  (Read 21154 times)
Re: New download will not run
« Reply #10 on: November 24, 2013, 05:06:17 PM »
Having said that MDI should still work and it does here once I chose Active Low for E-Stop, your xml had it active high, ie red cross in active low.
Just to clarify, you are just trying to test things out and dont have anything connected?
Offline cfell
  •  27 27
« Reply #11 on: November 24, 2013, 05:18:03 PM »
Set estop to active low green.  Still no response to MDI. command.  No cable connected to computer.  When .nc program is loaded I can click on start and green border appears around button.  Goes away if I click stop.  No change in X,Y,Z values.  I noticed CV mode is bordered with green, what does that mean?
« Reply #12 on: November 24, 2013, 05:21:49 PM »
I dont know what your problem is then as it is working fine here. I have E-Stop set to active low and I can then press Reset and it turns green. I can then go to MDI and command a move. If I turn on the Jog On/Off button so green is round it then I can jog via keyboard. If I load code and press start it works fine as well.
 CV means constant Velocity which is what you would normally be running anyway so its not a problem.
Offline cfell
  •  27 27
« Reply #13 on: November 24, 2013, 05:30:57 PM »
Thanks.  I will remove the installation and shut down, then reload it and see if anything changes.
Offline cfell
  •  27 27
« Reply #14 on: November 24, 2013, 05:51:48 PM »
Hood,  New clean installation seems to work.  I don't know what I managed to do wrong the first time.  Thanks for all your suggestions.
« Reply #15 on: November 25, 2013, 01:04:18 AM »
Glad to hear :)
