Hello Guest it is October 24, 2026, 10:50:31 AM
Author Topic: New download will not run  (Read 21159 times)
Offline cfell
  •  27 27
« on: November 24, 2013, 03:38:33 PM »
I have two licensed seats of Mach running on different machines.  Today I downloaded a new "demo" copy to a third (actually tried a XP and a W2000).  In each case the software loaded and appears normal however I can't get either to test.  I have entered commands on the MDI and loaded a program.  Neither execute.  Driver test runs good, diagnostics reports nothing. I can enter values in MDI such as 5.0 for X and it takes but button will not zero.  Simulate program run works.  What am I missing.
Thanks in advance.
Charlie
Re: New download will not run
« Reply #1 on: November 24, 2013, 03:47:31 PM »
You have the axes enabled in ports and pins?
Offline cfell
  •  27 27
« Reply #2 on: November 24, 2013, 04:03:18 PM »
Hood,  Yes X,Y,Z are green (enabled), all other choices on that screen are red. I accepted the default pin selection 2,3,4/6,7,8.  The reset button is bordered with green.  I attempted to change settings on Estop however it returns to enabled (green) even if I change it.
Charlie
« Reply #3 on: November 24, 2013, 04:05:53 PM »
Change the active state of the E-Stop and that will allow you to take Mach out of Reset.
Offline cfell
  •  27 27
« Reply #4 on: November 24, 2013, 04:28:45 PM »
If I click on the green enabled check and press enter it changes to red.  When I click apply then exit and return it is green again.  I have tried all combinations of active state and emulate in conjunction with the green enable and no joy. This occurs with no cable on the computer as well.
Charlie
« Reply #5 on: November 24, 2013, 04:38:26 PM »
The E-Stop is always enabled, Mach will not allow you to disable it as it is mandatory to have an E-Stop. You can trick it into thinking it has an E-Stop by changing the active state to Active Low and that will allow you to Reset Mach.
Offline cfell
  •  27 27
« Reply #6 on: November 24, 2013, 04:45:06 PM »
It was active low as default.  It is currently set at active low.  I am able to reset Mach and see the green border around the reset button however going to the mdi screen and entering g00 x5 does nothing.
Charlie
« Reply #7 on: November 24, 2013, 04:51:18 PM »
attach your xml please, that will be the quickest way for me to find the problem if I can :)
Offline cfell
  •  27 27
« Reply #8 on: November 24, 2013, 05:00:08 PM »
Here it is.  I would consider reinstalling Mach if this wasn't happening on two different computers.
« Reply #9 on: November 24, 2013, 05:03:54 PM »
You have the Jog Control switched off.
