Hello Guest it is September 05, 2026, 02:08:09 PM
Author Topic: Gcode won't start spindle HELP!  (Read 9981 times)
Offline pplug
  •  15 15
« on: November 10, 2013, 12:00:33 PM »
I have an interesting problem.
I wired up a probotix meteor for Mach3. I got everything to work perfectly but the spindle. The spindle works when you manually hit the start button or F5 but the gcode program won't start it. Am I missing a toggle button somewhere to run spindle with the M3 command? The gcode was generated by vcarve pro and looks looks good.
I've built or converted 3 routers over the years and have never run into this problem before!
Thanks for your help.
Re: Gcode won't start spindle HELP!
« Reply #1 on: November 10, 2013, 01:23:06 PM »
If you attach your xml, the code and your M3 macro I will have a look.
« Reply #2 on: November 10, 2013, 06:56:16 PM »
Mine was doing that the other day.  I shut down the cpu and restarted and now its' fine.
Don
Offline pplug
  •  15 15
« Reply #3 on: November 10, 2013, 07:43:19 PM »
Hood, I'll post the XML as soon as I can.
DonMarkey, the system has been restarted several time with no change.
Thanks for the thought though
Offline Bodini
  •  216 216
« Reply #4 on: November 10, 2013, 10:01:22 PM »
M3 quit working for me today in the middle of a routine its done a hundred times.  I opened M3 in Notepad++ (my favorite editor), resaved it, and it worked again.  Ugh.
