Hello
Guest
it is
October 21, 2026, 08:28:01 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Gcode won't start spindle HELP!
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Gcode won't start spindle HELP! (Read 10191 times)
pplug
15
on:
November 10, 2013, 12:00:33 PM »
I have an interesting problem.
I wired up a probotix meteor for Mach3. I got everything to work perfectly but the spindle. The spindle works when you manually hit the start button or F5 but the gcode program won't start it. Am I missing a toggle button somewhere to run spindle with the M3 command? The gcode was generated by vcarve pro and looks looks good.
I've built or converted 3 routers over the years and have never run into this problem before!
Thanks for your help.
Logged
Carnoustie, Scotland
Re: Gcode won't start spindle HELP!
Reply #1 on:
November 10, 2013, 01:23:06 PM »
If you attach your xml, the code and your M3 macro I will have a look.
Logged
DonMarkey
115
Reply #2 on:
November 10, 2013, 06:56:16 PM »
Mine was doing that the other day. I shut down the cpu and restarted and now its' fine.
Don
Logged
pplug
15
Reply #3 on:
November 10, 2013, 07:43:19 PM »
Hood, I'll post the XML as soon as I can.
DonMarkey, the system has been restarted several time with no change.
Thanks for the thought though
Logged
Bodini
216
Reply #4 on:
November 10, 2013, 10:01:22 PM »
M3 quit working for me today in the middle of a routine its done a hundred times. I opened M3 in Notepad++ (my favorite editor), resaved it, and it worked again. Ugh.
Logged
Print
Pages:
1
Go Up
« previous
next »
