Hello Guest it is November 23, 2026, 05:32:43 AM
Author Topic: erratic behaviour after customizing screen  (Read 14454 times)
« on: November 08, 2013, 05:36:05 AM »
Hi All,
A friend helped me customizing my Machturn screen , sometime after that my steppers started acting in a strange erratic way.
After some experimenting it shows that running a program in the customised screen caused erratic steppers  but running the same program while in the diagnostics screen my steppers are behaving ok.
This is out of our league , i have attached  my screenfile can somebody please  help  out???
Thanks   Mark
Re: erratic behaviour after customizing screen
« Reply #1 on: November 08, 2013, 07:35:03 AM »
Cant see how a screenset could make your steppers misbehave.
« Reply #2 on: November 08, 2013, 08:19:56 AM »
Hi Hood thanks for your reply :  its absolutely true, if i change screens or run from diagnostic screen everything is ok.
« Reply #3 on: November 08, 2013, 12:01:43 PM »
Pardon the question, but are you changing screen views, or profiles?
John Champlain
« Reply #4 on: November 08, 2013, 12:41:48 PM »
Hi John,
No change in profiles , i just load my cncprogram into Machturn , when i run it in my customscreen my steppers go erratic,
when i change screenview into diagnostics everything runs ok.
Mark
« Reply #5 on: November 08, 2013, 02:57:22 PM »
The only thing I could possibly think of that would cause a screen to affect the steppers is if the screen is very graphic intensive and your computers graphics card is very weak.
« Reply #6 on: November 09, 2013, 02:28:47 AM »
Well Hood, In fact my graphics are actually a bit on the weak size , is there a way i can test if this is the cause (other than changing my computerhardware)  ??
« Reply #7 on: November 09, 2013, 04:35:09 AM »
You could try either adding a button to disable toolpath view or temporarily remove the toolpath view from your screenset.
« Reply #8 on: November 10, 2013, 12:56:33 AM »
Thanks Hood , will try that
« Reply #9 on: November 11, 2013, 07:02:24 AM »
If you have a very large toolpath display and a weak PC, that could be the issue. Try turning off the toolpath and see if it helps.
A few users of my 2010 Screenset had a similar issue. (about .1%)
