Mach Discussion => General Mach Discussion => Topic started by: dikkieduk on November 08, 2013, 06:36:05 AM
Hi All,
A friend helped me customizing my Machturn screen , sometime after that my steppers started acting in a strange erratic way.
After some experimenting it shows that running a program in the customised screen caused erratic steppers but running the same program while in the diagnostics screen my steppers are behaving ok.
This is out of our league , i have attached my screenfile can somebody please help out???
Thanks Mark
Cant see how a screenset could make your steppers misbehave.
Hi Hood thanks for your reply : its absolutely true, if i change screens or run from diagnostic screen everything is ok.
Pardon the question, but are you changing screen views, or profiles?
John Champlain
Hi John,
No change in profiles , i just load my cncprogram into Machturn , when i run it in my customscreen my steppers go erratic,
when i change screenview into diagnostics everything runs ok.
Mark
The only thing I could possibly think of that would cause a screen to affect the steppers is if the screen is very graphic intensive and your computers graphics card is very weak.
Well Hood, In fact my graphics are actually a bit on the weak size , is there a way i can test if this is the cause (other than changing my computerhardware) ??
You could try either adding a button to disable toolpath view or temporarily remove the toolpath view from your screenset.
Thanks Hood , will try that
If you have a very large toolpath display and a weak PC, that could be the issue. Try turning off the toolpath and see if it helps.
A few users of my 2010 Screenset had a similar issue. (about .1%)
