Hello Guest it is October 21, 2026, 01:13:19 PM
Author Topic: Problems with Mach3 , Gcode or BobCad! and I am not sure whats going on!!  (Read 51832 times)
Re: Problems with Mach3 , Gcode or BobCad! and I am not sure whats going on!!
« Reply #30 on: November 09, 2013, 07:49:32 PM »
Thanks ever so much
« Reply #31 on: November 09, 2013, 07:52:44 PM »
Think thats a different file, its a pocket starting at centre and working out.
« Reply #32 on: November 09, 2013, 07:58:02 PM »
I opened the drawing in bobcad, and did a verify.
2 rectangles , the outside one is like 2mm bigger.
the inside one is a pocket.
basically, I am only taking like 2mm pocket in the Geometry, just to prove I can actually make it do anything,
« Reply #33 on: November 09, 2013, 08:10:34 PM »
Ok the issue was that I opened in V26, I just opened now in V25 and I get a pocket with the zig zag cut. However it is starting at the right hand end just as it is in Mach, see screenshot.
« Reply #34 on: November 10, 2013, 08:48:50 AM »
blah, ok  i wil need to consider upgrading. it looks better in 25 for sure.
just the learning stuff i have is with v24 and i am not crazy about change in the middle of it.
thanks a bunch, you a gentleman a and good judge of whiskey.
« Reply #35 on: November 10, 2013, 01:22:00 PM »
Sadly I only have V25 and V26 so cant look at it in V24 that you are using. Can you not select where you want the start point to be? certainly can in V25 and 26.
« Reply #36 on: November 10, 2013, 02:55:37 PM »
porbably can, but I am not wise in the way of bobCad yet. still learning.
I am sure I will find it. but its not the end of the world, if it doesnt.
