Hello Guest it is September 17, 2026, 12:08:51 AM
Author Topic: OEM code  (Read 14256 times)
Offline Quin
  •  34 34
OEM code
« on: November 04, 2013, 06:20:10 PM »
One of my screen buttons needs to be inoperable when the Estop is active.  I can
't seem to find the OEM code for Estop so I can use it in the script for my button.
Any help would be appreciated.
Quin
Re: OEM code
« Reply #1 on: November 05, 2013, 01:59:33 AM »
1021 for Reset button
800 for Reset LED.
Offline Quin
  •  34 34
Re: OEM code
« Reply #2 on: November 05, 2013, 01:54:31 PM »
Hi Hood,
These codes don't seem to work.  I'm using version R1.84. Does that make a difference?
I'm looking for the estop triggered by the mouse on the screen, not the estop button on the machine.
Quin
Re: OEM code
« Reply #3 on: November 05, 2013, 05:29:08 PM »
Dobutton(21) is reset and Getled(0) is the led.
V1.84 is before the change over in Buttons,etc
Offline Quin
  •  34 34
Re: OEM code
« Reply #4 on: November 05, 2013, 08:34:25 PM »
The button works OK,  However the LED code of 0 does not.
Am I doing this correct:  I place a new LED on the screen, and give it an OEMcode of 0.  When I go to the Mach3 screen reload my saved screen, I get a gray LED that does not respond to changes in the Estop.
Quin
Re: OEM code
« Reply #5 on: November 05, 2013, 08:57:04 PM »
The problem is the code is a standard code NOT an OEMcode. You are using a modern screen designer on an ancient version of mach3. Either try Mach3Screen or the designer before that Screen tweaker.
Best to upgrade to a modern version of mach3 for full support and functions.
Re: OEM code
« Reply #6 on: November 06, 2013, 02:18:38 AM »
You dont need the LED on screen, all you need to do is look at the LED state in your VB.
I have just tested with this
If GetLED(0) Then
MsgBox("Mach in Reset")
Else
MsgBox("Mach out of Reset")
End If
It is working correctly so it is likely your script that is incorrect.
If you explain exactly what you are trying to do and paste the script then maybe you can be helped.
Offline Quin
  •  34 34
Re: OEM code
« Reply #7 on: November 10, 2013, 08:06:52 PM »
Thanks guys,
I got it working with a simple:
if not getled(0) then
Thanks again,
Quin
