Hello Guest it is November 13, 2026, 11:36:28 AM
Author Topic: Restarting a JOB  (Read 9602 times)
Restarting a JOB
« on: October 23, 2013, 02:55:41 AM »
Hi All
one of my power points tripped which runs the motors the Mach PC was still working and one so I thought all I would do it say continue job well what it did it try go to the origin of where the code started - I lifted the Z axis so it would clear the part but it dropped the Z Axis and moved directly to the start point destroying the part in the process.
How do I set it up that the X & Y move with the Z set to home when in such a situation?
thank you
Mark
Re: Restarting a JOB
« Reply #1 on: October 23, 2013, 03:09:18 AM »
I don't think this is very clear
Let me do this slower
The motors and controller tripped the Mach Pc still was running and gave and Estop Error
the spindle was at a co-ordinate and  5mm plunged into the part
I cleared the Estop error and lifted the Z axis to clear the part and hit start / cycle.
the Z Axis went back to -5mm and then tried to move to the starting point of the line of code it was at - all would have been perfect if the Z axis remained above the part how do I make that happen in future?
thanks
Mark
« Reply #2 on: January 16, 2014, 06:00:28 AM »
I have also been having this issue. Did you find a fix or can anyone suggest something to stop the Z from moving first and crashing into the piece?
« Reply #3 on: January 16, 2014, 10:41:28 AM »
Set up a safe Z.
